boblou2590
#1 Posted : Friday, July 31, 2015 12:53:03 PM(UTC)
boblou2590
everything works except the spin cycle. I`ve replaced the timer and it still does the samething.It`s a GE Profile about 7 years old. Any suggestions would be appreciated
Thanks Bob Allen
CletusT
#2 Posted : Wednesday, August 5, 2015 8:13:31 AM(UTC)
CletusT
Bob, it sounds like a drive problem. Is it direct drive or belt drive?
Also the clutch can get bad, allowing agitation, but no spin after rinse.
Simon / APP Team
#3 Posted : Wednesday, August 5, 2015 8:33:12 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Bob.
In order to provide you with correct diagnostics and the parts to fix the problem we need a complete washer model number.
Thank you,
Simon.
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
wfc7500vw no high spin (Washer Repair)
by wilsonjiaho 6/14/2024 8:53:25 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
Scraping sound spinning (Washer Repair)
by ADKwoman 5/3/2024 12:27:02 PM(UTC)
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Wf330 stuck on spin (Washer Repair)
by Guest 5/2/2024 3:23:56 AM(UTC)
Kenmore 110.47566601 makes loud spin noise (Washer Repair)
by Guest 4/6/2024 7:42:40 PM(UTC)
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Shaking while spinning (Washer Repair)
by Guest 3/20/2024 8:39:31 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
