spencer5
#1 Posted : Thursday, December 6, 2012 6:15:05 AM(UTC)
spencer5
Hello. I have a WFW9640 Duet Steam I bought from Lowe's. The washer washes fine but when it comes time to spin it spins up but cant seem to find a balance and does not kick into high speed. Must be some kind of "tilt" mechanism. It will stop and try to re balance only to start the process over and do it again. I checked the bearing and belt gear in the back they seem fine. The shocks and springs are in tact and it drains fine. I also tried with the machine empty and with one towel both times worked fine. I ran a load of 7 towels and applied pressure to the front and back of the outer tub with my hands as it started spinning to help it balance it and it worked. Also. might mention the tub seems to be angling down from the front to the back. Not sure what the exact fall but its noticeable. Do the springs or shocks ever need replacing? If not, any ideas? The machine is only 13 months old. Thanks in advance for any help.
Steve
ScottJCPP
#2 Posted : Monday, July 27, 2015 7:11:19 AM(UTC)
ScottJCPP
Hey Spencer5 !
I have a similar problem with a much older HE3T (same basic washer). Did you ever find a fix?
Whirpool Duet GGW9250PL0 won't start/spin (Dryer Repair)
by Smallbej 2/18/2020 7:09:30 PM(UTC)
Whirpool Duet Sport won't run Diagnostic Test (Washer Repair)
by RIPPTA 11/19/2019 1:28:05 PM(UTC)
Whirpool duet Dryer (Dryer Repair)
by Louiella 1/23/2018 1:55:01 PM(UTC)
Whirpool Duet (first gen) (Dryer Repair)
by jmden 8/23/2017 7:03:25 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
Whirpool Duet F70/F71/Beep Error (Washer Repair)
by ADS66 9/30/2015 5:54:08 AM(UTC)
Whirpool Duet Issues (Dryer Repair)
by joshhaye44 6/20/2015 11:11:50 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Whirpool Duet Washer new circut board wont work F11 code still up (Washer Repair)
by Rickvial88 7/10/2013 7:33:37 AM(UTC)
whirpool duet (Dryer Repair)
by jesquivel98 4/9/2013 9:43:06 PM(UTC)
Whirpool Duet Dryer - Just Stopped! (Dryer Repair)
by Gary Prentice 12/7/2011 6:37:20 AM(UTC)
whirpool duet f06 fault (Washer Repair)
by jeff and Susan Coffing 11/8/2011 4:32:51 PM(UTC)
whirpool duet washer door is not opening staying locked (Washer Repair)
by sonya46 10/23/2011 6:12:22 AM(UTC)
Whirpool Duet Sport Washer (Washer Repair)
by MBKeith 7/18/2011 9:51:09 AM(UTC)
Whirpool Duet Washer wont start (Washer Repair)
by smooothopr 6/8/2011 5:32:27 AM(UTC)
