jesquivel98
#1 Posted : Wednesday, April 10, 2013 12:43:06 AM(UTC)
jesquivel98
I have a whirpool duet dryer and my 220 switch was old and needed replacement. Anyhow when I plug the dryer up and went to start the dryer something in the back popped and dryer stopped working completely. Im wanting to know what to check first. If there is a fuse that pops or if its the whole motherboard
#2 Posted : Wednesday, April 10, 2013 4:27:29 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Also I do not know what "220 switch" you are referring to?
jesquivel98
#3 Posted : Wednesday, April 10, 2013 12:05:07 PM(UTC)
jesquivel98
Model number gew9250pw1 and the the 220 switch is the 3 prong connector that goes to the wall
#4 Posted : Wednesday, April 10, 2013 1:49:16 PM(UTC)
Parts for Whirlpool GEW9250PW1 Dryer - AppliancePartsPros.com
As you can see from the tech sheet there is no fuse protecting the control board.
File Attachment(s):
GEW9250.pdf (342kb) downloaded 4 time(s).
You cannot view/download attachments. Try to login or register.
jesquivel98
#5 Posted : Wednesday, April 10, 2013 2:19:21 PM(UTC)
jesquivel98
So should I check the thermal fuse first or do u think it would be the motherboard
#6 Posted : Thursday, April 11, 2013 5:36:56 AM(UTC)
"220 switch is the 3 prong connector" so this is the line/power cord, correct?
It sounds like you must have made a mistake when you connected it, so first you have to check that it is wired OK.
What was the original problem?
Next I would check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
The thermal fuse just cuts power to the motor.
The display should still light up.
Whirpool duet Dryer (Dryer Repair)
by Louiella 1/23/2018 4:55:01 PM(UTC)
Whirpool Duet (first gen) (Dryer Repair)
by jmden 8/23/2017 10:03:25 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 10:01:30 PM(UTC)
Whirpool Duet F70/F71/Beep Error (Washer Repair)
by ADS66 9/30/2015 8:54:08 AM(UTC)
Whirpool Duet Issues (Dryer Repair)
by joshhaye44 6/20/2015 2:11:50 PM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/26/2015 12:47:32 AM(UTC)
Whirpool Duet Washer new circut board wont work F11 code still up (Washer Repair)
by Rickvial88 7/10/2013 10:33:37 AM(UTC)
Whirpool Duet (Washer Repair)
by spencer5 12/6/2012 9:15:05 AM(UTC)
Whirpool Duet Dryer - Just Stopped! (Dryer Repair)
by Gary Prentice 12/7/2011 9:37:20 AM(UTC)
whirpool duet f06 fault (Washer Repair)
by jeff and Susan Coffing 11/8/2011 7:32:51 PM(UTC)
whirpool duet washer door is not opening staying locked (Washer Repair)
by sonya46 10/23/2011 9:12:22 AM(UTC)
Whirpool Duet Sport Washer (Washer Repair)
by MBKeith 7/18/2011 12:51:09 PM(UTC)
Whirpool Duet Washer wont start (Washer Repair)
by smooothopr 6/8/2011 8:32:27 AM(UTC)
whirpool duet sport washer (Washer Repair)
by racnrob 12/24/2010 11:50:12 AM(UTC)
Whirpool duet sport - how much water it uses on a normal load??? (Dishwasher Repair)
by wurma01 12/14/2010 9:45:44 AM(UTC)
