My Whirlpool gas dryer will not heat. It will heat up intermittently for a minute or two and then no heat. There are not blockages in the exhaust line.
You will need to check and see if the gas coils are bad and will need to be replaced on the unit. This is the main cause for the issue your having. Part number: AP3094251
