smokyjoeko
#1 Posted : 10 years ago
smokyjoeko
My son has a GE Mod. GSS25QFMC WW refrigerator freezer that wont go into defrost. Heater resistance is 17 ohms. From what I read that is good. Is there a way to force it into defrost? Resistance readings are taken with freezer cold. Defrost heater and thermostat replaced about a year ago. Main board replaced may 3 or 4 years ago. Defrost did work after heater replaced. Again is there a way to force it into defrost. What should we check next and how?
Jeff / APP Team
#2 Posted : 10 years ago
Jeff / APP Team
Hello Smokyjoeko. You can force defrost by using a jumper wire on the main board and going across the line (J-11) and defrost terminal (J-9). This should turn the heater on. If the heater comes on, then the heater and the defrost thermostat are good and the main board is bad. If the heater does not come on, and the heater is reading closed for continuity, you will need to replace the defrost thermostat.
Part number: AP3884317
smokyjoeko
#3 Posted : 10 years ago
smokyjoeko
Sorry its taken so long to get back. Looks like the main board is bad My son well be ordering one. Thanks again.
smokyjoeko
#4 Posted : 10 years ago
smokyjoeko
My son completely defrosted freezer then replaced main board. 4 days later evaporator is froze over again. How often should it go into defrost? If it does not go into defrost soon what should we do?
Jeff / APP Team
#5 Posted : 10 years ago
Jeff / APP Team
If the board is new, it should go into defrost once every day. If the unit is not defrosting, you will need to check the thermostat and the heater in the unit.
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 8 years ago
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 8 years ago
defrost not working (Refrigerator & Freezer Repair)
by carlosl. 12 years ago
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 13 years ago
by swallman 13 years ago
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 14 years ago
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 14 years ago
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 15 years ago
by smodellb 15 years ago
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 15 years ago
by red arrow 57 15 years ago
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 16 years ago
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 16 years ago
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 16 years ago
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 16 years ago
