carlosl.
#1 Posted : 12 years ago
carlosl.
Evaporeror full of ice and warm in the refrigerator
#2 Posted : 12 years ago
Hello,
Pull the refrigerator out of the wall and unplug it. Remove the cover from the main control board and remove the wire from the J9 terminal. Measure the resistance between this wire and the wire connected to J7-9 pin.
If the reading is around 22 Ohms, replace the main control board.
If the reading is ∞ Ohms, remove the rear panel in the freezer and check for continuity the heater and the overtemperature thermostat separately.
It is a good idea to replace the temperature sensor located on top of the evaporator coils in any case. This part is inexpensive and will make the repair more reliable.
- The main control board Part number: WR55X10942
- The heater Part number: WR51X10038
- The overtemperature thermostat Part number: WR50X10068
- The temperature sensor Part number: WR55X10025
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 8 years ago
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 8 years ago
by smokyjoeko 10 years ago
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 13 years ago
by swallman 13 years ago
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 14 years ago
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 14 years ago
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 15 years ago
by smodellb 15 years ago
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 15 years ago
by red arrow 57 15 years ago
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 16 years ago
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 16 years ago
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 16 years ago
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 16 years ago
