carlosl.
#1 Posted : Wednesday, May 15, 2013 8:35:28 PM(UTC)
carlosl.
Evaporeror full of ice and warm in the refrigerator
#2 Posted : Thursday, May 16, 2013 2:49:54 PM(UTC)
Hello,
Pull the refrigerator out of the wall and unplug it. Remove the cover from the main control board and remove the wire from the J9 terminal. Measure the resistance between this wire and the wire connected to J7-9 pin.
If the reading is around 22 Ohms, replace the main control board.
If the reading is ∞ Ohms, remove the rear panel in the freezer and check for continuity the heater and the overtemperature thermostat separately.
It is a good idea to replace the temperature sensor located on top of the evaporator coils in any case. This part is inexpensive and will make the repair more reliable.
- The main control board Part number: WR55X10942
- The heater Part number: WR51X10038
- The overtemperature thermostat Part number: WR50X10068
- The temperature sensor Part number: WR55X10025
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 9/13/2017 12:37:45 PM(UTC)
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 2/3/2017 10:58:43 AM(UTC)
by smokyjoeko 4/7/2015 7:44:59 AM(UTC)
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 4/30/2012 2:50:08 PM(UTC)
by swallman 2/18/2012 5:29:58 AM(UTC)
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 9/21/2011 3:22:27 PM(UTC)
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 10/13/2010 4:33:52 PM(UTC)
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 7/21/2010 2:43:00 PM(UTC)
by smodellb 3/28/2010 5:02:17 PM(UTC)
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 2/6/2010 6:19:27 AM(UTC)
by red arrow 57 10/18/2009 7:35:40 AM(UTC)
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 9/19/2009 8:19:56 AM(UTC)
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 8/31/2009 5:03:59 PM(UTC)
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 6/30/2009 6:05:59 AM(UTC)
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 3/27/2009 6:28:53 AM(UTC)
