mdlee
#1 Posted : Monday, April 6, 2015 7:19:48 AM(UTC)
mdlee
My washer shakes VIOLENTLY during the spin cycle, in the last four months I have changed the gear case but I haven't done anything else to it. But since then it just bangs around loudly. PLEASE HELP!!!!! :confused::confused:
sidfink43
#2 Posted : Monday, April 6, 2015 3:19:28 PM(UTC)
sidfink43
I cannot get your model number to come up as a valid model, but the generic diagnosis here is a damaged support structure. Look for hairline cracks, and if the model has springs check them out.
mdlee
#3 Posted : Monday, April 6, 2015 5:06:34 PM(UTC)
mdlee
I apologize the model number is WTW4950xw1...I had the numbers wrong
mdlee
#4 Posted : Monday, April 6, 2015 5:27:27 PM(UTC)
mdlee
I entered the model number wrong..... WTW4950XW1
mdlee
#5 Posted : Tuesday, April 7, 2015 4:19:17 PM(UTC)
mdlee
Can someone help me with my washer issue? WTW4950XW1...
The tub spins violently when in spin cycle... the springs seem to be in good condition and I can't see any other issue.
sidfink43
#6 Posted : Tuesday, April 7, 2015 4:23:56 PM(UTC)
sidfink43
This is not something that is easy to diagnose, and almost impossible to diagnose without being there because there can be several causes, and some are not even visible. All I can say is what I said before, check for hairline cracks or some other problem with the support structure. Also check to see that the machine is level.
Guest (4)
Whirlpool top loader wtw5015lwo not draining (Washer Repair)
by Guest 12/30/2023 11:09:00 AM(UTC)
Whirlpool Top Loader Not Finishing Load (Washer Repair)
by gustafa75 4/10/2022 3:32:28 PM(UTC)
Whirlpool Top Loader Inner Basket Rocks on Final Spin (Washer Repair)
by SleepingDragon 6/27/2017 6:52:26 AM(UTC)
Whirlpool top loader not spinning on final rinse (Washer Repair)
by staton4 5/10/2017 8:22:38 PM(UTC)
Whirlpool top loader not draining (Washer Repair)
by triehle 8/4/2016 5:18:12 PM(UTC)
Whirlpool top loader will not complete cycle (Washer Repair)
by Lkajrcb 10/16/2015 7:37:50 PM(UTC)
Whirlpool top loader squeaking/creaking (Washer Repair)
by concertina 10/7/2015 5:38:43 PM(UTC)
Kenmore/Whirlpool top loader, lid lock clicking (Washer Repair)
by Dave Roberts 4/15/2015 5:26:31 PM(UTC)
Whirlpool top loader (Washer Repair)
by Spano10038 3/1/2015 11:26:41 AM(UTC)
Whirlpool top loader washer (Washer Repair)
by loriehunter 2/18/2014 6:54:21 PM(UTC)
Whirlpool top loader slow spin cycle (Washer Repair)
by Re Vera 6/24/2013 12:34:34 PM(UTC)
whirlpool Top loader not spinning or agitating (Washer Repair)
by jimmriley 6/23/2013 12:14:11 PM(UTC)
whirlpool top loader washer not working (Washer Repair)
by frankhvac@yahoo.com 12/11/2012 7:32:12 PM(UTC)
Whirlpool Top Loader "Knocks" under load (Washer Repair)
by keiser 5/15/2012 5:30:19 PM(UTC)
Whirlpool top loader leaks, not sure if it will spin (Washer Repair)
by OP4500 1/16/2012 6:10:01 PM(UTC)
