Washer wont spin clutch, lid switch, drive tube and coupling are fine. Need help.
Groups: Expert
Does it drain? Does the motor run when in spin mode? Does the clutch hub rotate while in spin mode?
Eric
Originally Posted by: fairbank56 Does it drain? Does the motor run when in spin mode? Does the clutch hub rotate while in spin mode?
Eric Eric, yes to all three. Clutch assembly installed new, motor runs fine, aggitates fine, coupler is new.
Groups: Expert
So, while you are observing the clutch hub spinning, look up into the brake hub. Is the basket drive rotating? Bottom of basket drive consists of the brake shoes and brake spring. If they are rotating but basket is not, then your drive block is suspect. If basket drive is not spinning, then the clutch band is slipping or the brake cam driver is broken.
Eric
