randysshkr
#1 Posted : Friday, May 15, 2009 4:14:51 PM(UTC)
randysshkr
The fan motor was not working. I checked fan motor windings and they were open. I also checked with direct power connection. I ordered a new fan motor and it is not working but it is a good motor. I'm getting 120 volts to my motor. I manually turned defrost timer to defrost and heater heated up and timer took it out of defrost after it timed out. I don't understand why new fan won't work. I cannot read the schematics on the back of refrigerator because they're all scuffed up, and did not find any paperwork in compressor area.
#2 Posted : Friday, May 15, 2009 8:32:40 PM(UTC)
If you are getting 120VAC to the new motor then it must work. Double check all connections. Also the fan could be off when the door is open.
The only way to find the wiring diagram for Kenmore fridge is to buy it from Sears if it's still available.
randysshkr
#3 Posted : Friday, May 15, 2009 8:38:55 PM(UTC)
randysshkr
thanks for responding. I was getting 120 volts with door open, however I did try pushing door switches in. I guess I'll put new connectors on wire and try again. This really has me puzzled.
#4 Posted : Friday, May 15, 2009 8:46:46 PM(UTC)
Good luck. Keep us posted.
holston1948
#5 Posted : Saturday, May 16, 2009 1:32:34 PM(UTC)
holston1948
i have a kenmore side by side refrig freezer and the compressor will not come on
woodchuckie
#6 Posted : Saturday, May 16, 2009 1:55:34 PM(UTC)
woodchuckie
problems with fan motor not working, frig wire orientation in relation to fan clip et (Refrigerator & Freezer Repair)
by ddgiz 4/29/2010 4:52:38 PM(UTC)
Condenser Fan Motor not working (Refrigerator & Freezer Repair)
by scieslicki 9/26/2009 6:01:41 AM(UTC)
Condenser fan motor not working (Refrigerator & Freezer Repair)
by Magilla Gorilla 7/8/2008 12:28:32 PM(UTC)
GE Refrigerator/Freezer Condensor fan motor not working (Refrigerator & Freezer Repair)
by Brian Mosdal 6/21/2008 6:34:58 AM(UTC)
