jawalker85
#1 Posted : Thursday, May 14, 2009 8:01:06 PM(UTC)
jawalker85
My dryer is starting to act up. took off the access panel on the back and could see burner come on and glow but it would go off. checked gas valve solenoids with meter and both and continuity. so i took it all apart and what do you know the pilot lit up. so i put it all back together and it wouldn't light...go figure... so i took it all back apart and made it run and since the gas is on and the glow thingy is glowin but won't allow the gas to flow out and light, the only thing i can see it being is the flame sensor contraption mounted through the window on the burner pipe thing. am i going in the right direction? any help would be appreciated...
sorry for the less than technical vocabulary...i had no idea how a dryer worked until i took it apart...and i had to get on the internet to see how to do that!
#2 Posted : Friday, May 15, 2009 8:04:38 PM(UTC)
How did you check the gas valve coils? Simple continuity test does not prove they are good. You can find the instructions in one of our previous posts: http://forum.appliancepartspros...er-runs-but-no-heat.html
jawalker85
#3 Posted : Saturday, May 16, 2009 6:29:14 PM(UTC)
jawalker85
i just checked them with a meter because i read somewhere that everything was a normally closed switch... i guess i confused myself with everything i read about it. thanks for the info and i'll check them again...i'll post again if it turns out to be my problem...
Frigidaire Dryer FER231AS2 Issues after multiple repairs (Dryer Repair)
by tjpowers11 1/30/2022 12:27:36 PM(UTC)
Frigidaire Dryer FER231AS2 Issues (Dryer Repair)
by tjpowers11 1/30/2022 12:26:12 PM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
Frigidaire dryer stopping shortly after starting (Dryer Repair)
by jswNV 9/13/2020 10:24:50 AM(UTC)
frigidaire dryer combo (Dryer Repair)
by MIGUEL3811 12/27/2019 3:24:18 PM(UTC)
Frigidaire Dryer possessed by evil spirits (Dryer Repair)
by mdinn511 7/27/2019 12:35:05 PM(UTC)
Loud noise during anti static cycle on my Frigidaire dryer (Dryer Repair)
by GR8TSCT99 5/1/2019 4:40:02 AM(UTC)
Frigidaire Dryer Won't Turn Off (Dryer Repair)
by candy1524 3/12/2018 2:33:20 PM(UTC)
Frigidaire dryer no power (Dryer Repair)
by Newgirl 8/16/2017 1:01:59 PM(UTC)
Frigidaire Dryer Auto Sense Not Working (Dryer Repair)
by Lerxst 7/27/2017 6:21:23 PM(UTC)
frigidaire dryer runs for few minutes (Dryer Repair)
by limpy 7/2/2017 1:41:44 PM(UTC)
Frigidaire Dryer beeps 3 times - no start (Dryer Repair)
by boriska13 6/27/2017 8:59:46 PM(UTC)
Frigidaire dryer replace bulb (Dryer Repair)
by Sam Hobbs 12/11/2016 6:11:30 PM(UTC)
Frigidaire dryer beep 3 times won't start (Dryer Repair)
by TjaturSubagio 8/28/2016 11:05:10 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
