craziegram
#1 Posted : Monday, January 19, 2015 2:42:42 PM(UTC)
craziegram
On the automatic dry cycle the knob/timer will not advance and the dryer will just keep running unless i go down and turn it off. I also think it does not heat up when it should. I took off the little plastic piece and watched it glow but it will not ignite the flame. However, on the timed side of the dryer/knob area, i can turn the knob to 30 mins and the knob/timer will advance and the ignitor will light the flame and the clothes will dry. So it is like only half my timer/knob thing don't work. The automatic dry half won't work (advance) and won't heat up like it should but the other half on the timed side works ok. I would like to narrow down buying parts from the cycling thermostat, or the thermal fuse and/or coils, or just the timer itself. if i buy the timer and it is not the problem can I send this back for a refund?
craziegram
#2 Posted : Tuesday, January 20, 2015 7:19:09 PM(UTC)
craziegram
Originally Posted by: craziegram Go to Quoted Post
On the automatic dry cycle the knob/timer will not advance and the dryer will just keep running unless i go down and turn it off. I also think it does not heat up when it should. I took off the little plastic piece and watched it glow but it will not ignite the flame. However, on the timed side of the dryer/knob area, i can turn the knob to 30 mins and the knob/timer will advance and the ignitor will light the flame and the clothes will dry. So it is like only half my timer/knob thing don't work. The automatic dry half won't work (advance) and won't heat up like it should but the other half on the timed side works ok. I would like to narrow down buying parts from the cycling thermostat, or the thermal fuse and/or coils, or just the timer itself. if i buy the timer and it is not the problem can I send this back for a refund? I am going with the gas valve solenoid makes the most sense. thanks anyways
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Inglis Dryer - Works but No Heat (Dryer Repair)
by Ransom 11/3/2014 2:38:44 PM(UTC)
Whirlpool Inglis Dryer Wont Heat Up and Keeps Running (Dryer Repair)
by johnnymac813 1/8/2014 4:39:14 PM(UTC)
Inglis Dryer Runs/no heat (Dryer Repair)
by gkacsandi 9/26/2012 12:29:44 PM(UTC)
Inglis Dryer, runs a few seconds, emitting odor (Dryer Repair)
by nrw3d 2/7/2012 1:50:56 PM(UTC)
Old Inglis Dryer-No Thermal Fuse? (Dryer Repair)
by volvik 1/1/2012 3:47:27 PM(UTC)
Inglis dryer, unusual code and cycle problems (Dryer Repair)
by Billie87 7/15/2011 8:14:59 AM(UTC)
inglis dryer (Dryer Repair)
by mrfixit3 7/5/2011 5:18:20 PM(UTC)
Inglis Dryer running hot (Dryer Repair)
by drdoodlebug 10/15/2010 7:50:39 PM(UTC)
Inglis dryer heats and Dry's when it feels like it. (Dryer Repair)
by Chakeeshan 5/13/2010 9:51:15 AM(UTC)
Inglis Dryer - Metal smell and no heat (Dryer Repair)
by jessch 10/24/2009 10:15:58 AM(UTC)
Inglis Dryer will turn but no heat (Dryer Repair)
by ndstaging 10/5/2009 8:00:43 AM(UTC)
inglis dryer low heat (Dryer Repair)
by Casego 8/17/2009 2:43:19 PM(UTC)
Inglis Dryer no heat, otherwise runs fine (Dryer Repair)
by Islandbob 5/26/2008 9:49:09 AM(UTC)
by Islandbob 5/22/2008 9:53:52 AM(UTC)
