SteveMPi
#1 Posted : Wednesday, December 31, 2014 1:45:07 PM(UTC)
SteveMPi
I have a dryer that runs but doesn't heat. I checked the guide included inside the dryer. The high limit thermostat, thermal fuse, and heating element all test out good with a meter. The next step was to measure resistance across P3 and P6 of connector P14. The measured resistance was 18.6 k-ohms. The guide says if 5 to 15 k-ohms replace control module. If open replace the dryer thermal fuse. The trouble shooting portion stops there. Is the resistance too high and it's looking like an open to the control module? What next?
#2 Posted : Thursday, January 1, 2015 2:15:02 AM(UTC)
Parts for Maytag MEDE500VW1 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet
I do not think that the thermistor is out too much as the board would give you a F-22 error.
Take a look at page 16 of the tech sheet.
You did not say but have you checked the power.
Most of the unit will run off of half the line but the heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
MEDE500.pdf (1,999kb) downloaded 3 time(s).
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
