Patty
#1 Posted : Sunday, December 16, 2007 4:31:36 AM(UTC)
Patty
Hi, I replaced the bottem element on my older Whirlpool oven ( the old one didn't have any holes or bubbles, so it probably was not the problem ) The oven clicks as usual when I try to turn it on, but the oven indicator light doesn't come on and the bottom element still doesn't get hot. If I set it to broil, it clicks as usual and the top element does get red, but the oven indicator light doesn't come on as it should, all four burners on the stove top are working properly, and the indicator lights all come on for them. Any ideas why the bottom element isn't working? thanks!:rolleyes:
kawfeeman
#2 Posted : Sunday, December 16, 2007 9:02:16 AM(UTC)
kawfeeman
you are losing 110vac from one side of the element or the other ... ( not for anything, but w/ high voltage like 220vac, you should call a tech ...) you could have a broken wire or a thermal cutout which is open amongst other things...
Kenmore GAS Range. Model:79079013101 won't bake heat (Oven Repair (including Ranges and Cooktops))
by jfii 12/6/2019 12:56:05 PM(UTC)
Frigidaire range won't bake (Oven Repair (including Ranges and Cooktops))
by lenjack 6/17/2018 2:25:06 PM(UTC)
Electric oven won't bake, when knob is set to bake it tries to work (Oven Repair (including Ranges and Cooktops))
by jcvencill 12/6/2015 12:51:47 PM(UTC)
Jenn Air Range/Convection oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by Pamwest 11/30/2015 11:09:20 AM(UTC)
Upper oven won't bake (Oven Repair (including Ranges and Cooktops))
by stefanino 8/12/2014 8:54:13 AM(UTC)
Bottom oven won't bake (Oven Repair (including Ranges and Cooktops))
by vfrclark 12/6/2013 5:42:20 AM(UTC)
Maytag Double Wall Ovens Won't BAKE (Oven Repair (including Ranges and Cooktops))
by z28931le 7/13/2013 9:12:06 AM(UTC)
Frigidaire Range FEF365ASG won't bake or heat oven chamber (Oven Repair (including Ranges and Cooktops))
by lostsole1976 1/7/2013 11:03:19 AM(UTC)
Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by ConnerNA 9/30/2012 5:05:45 AM(UTC)
Won't bake or broil after element replaced (Oven Repair (including Ranges and Cooktops))
by kmall002 4/12/2012 1:49:23 PM(UTC)
by carpool 12/27/2011 10:52:01 PM(UTC)
Bake Unit Won't bake! (Oven Repair (including Ranges and Cooktops))
by Lisa-Lion 11/8/2010 8:15:13 AM(UTC)
GE Profile oven won't bake - broil is OK (Oven Repair (including Ranges and Cooktops))
by eric512 12/11/2009 9:23:12 AM(UTC)
Oven won't bake or broil no error showing (Oven Repair (including Ranges and Cooktops))
by jallen 2/2/2009 6:48:53 AM(UTC)
Oven won't bake (Oven Repair (including Ranges and Cooktops))
by MMegenity 7/11/2008 7:28:35 AM(UTC)
