kmall002
#1 Posted : Thursday, April 12, 2012 1:49:23 PM(UTC)
kmall002
the bottom element of my Frigidaire range (fefl67gca) burnt out this weekend and I promptly replaced it with a new one. Now, neither element will heat on either bake or broil setting. Does anyone have a thought on what could be causing this? Any help in avoiding expensive repair for a not so expensive range would be greatly appreciated.
#2 Posted : Friday, April 13, 2012 3:41:24 AM(UTC)
Replacement parts for Frigidaire FEFL67GCA Frigidaire/range | AppliancePartsPros.com
Here is the tech sheet.
http://manuals.frigidaire.com/p...ingfield/316441433en.pdf
Sounds like when the element blew it also blew the control (clock/timer).
I would check the wiring from the control to the elements.
Also I am assuming everything on the control board looks OK, just no heat and that the stove top elements work OK.
Check to be sure you can get the overlay off the old control before ordering as you may also need a new overlay.
