respup
#1 Posted : Tuesday, May 12, 2009 7:29:13 PM(UTC)
respup
I have a maytag dryer that wont start, like no power. does anyone know what it could be?I'm thinking that it's the switch by the door. not sure
#2 Posted : Wednesday, May 13, 2009 2:44:28 AM(UTC)
Could also be the thermal fuse but cannot be of much help hear without a Model Number.
Often it is a white device attached to the blower housing
respup
#3 Posted : Wednesday, May 13, 2009 6:11:40 AM(UTC)
respup
my model number is HYE3657AYW maytag
#4 Posted : Wednesday, May 13, 2009 7:00:01 AM(UTC)
Here are your parts, note the wiring diagrams are at the bottom
Replacement parts for MAYTAG HYE3657AYW | AppliancePartsPros.com
Could be the door switch
The thermal fuse as mentioned earlier. This is probably the most common cause.
Also the start switch
Or the motor itself.
Try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
With a unit that appears totally dead it is bets to check that you are getting the correct voltages at the plug first using a meter.
billy andrus
#5 Posted : Tuesday, May 19, 2009 5:17:18 AM(UTC)
billy andrus
mod. pyet344ayw
#6 Posted : Tuesday, May 19, 2009 7:18:33 AM(UTC)
billy andrus
Please start your own thread in this forum using Post New Thread, tagging onto a thread with a different Model Number will just confuse things
Thanks in advance.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
