bdeforce
#1 Posted : Thursday, October 2, 2014 4:26:01 AM(UTC)
bdeforce
The temperature set points are 3 F for the freezer and 42 F for the fridge. A thermometer reads 14 F for the freezer and 34 F for the fridge. I assume this means the vent/damper is not working. Any thoughts on how to confirm this and what parts to replace? Thank you
#2 Posted : Saturday, October 4, 2014 1:54:38 AM(UTC)
Freezer temperature too high, remove freezer back panel and describe frost pattern, defrost if total, heavy frost.
bdeforce
#3 Posted : Tuesday, October 7, 2014 6:07:31 PM(UTC)
bdeforce
Thanks for the reply. I gave some incorrect information. I realize the digital thermometer I was using had 14 F as a minimum. I have since used a better thermometer and the temp of the freezer is about 2 F.
Since my last reply, I ran the automatic diagnostics and nothing failed. The same day I covered the vents with electrical tape. The refrigerator is now holding steady at 38 F. Does this mean the vent/damper is not working?
#4 Posted : Wednesday, October 8, 2014 1:38:28 AM(UTC)
Check to see if the damper door is stuck open. If ok, you might have a bad fresh food thermistor, or a bad electronic module.
bdeforce
#5 Posted : Wednesday, October 8, 2014 8:45:49 AM(UTC)
bdeforce
Sorry for my limited knowledge, but can you tell me how to check the damper and where it is located?
#6 Posted : Thursday, October 9, 2014 1:46:47 AM(UTC)
You will see a vent in the refrigerator section, upper, left. Remove the cover screws to expose the damper door.
You can turn the fresh food thermostat back and forth to see if the damper door will open and close.
LG LFX31925ST Refrigerator is freezing (Refrigerator & Freezer Repair)
by rick1911 2/24/2021 10:30:14 AM(UTC)
Frigidaire 'Tall Twin' Refrigerator is freezing food. (Refrigerator & Freezer Repair)
by jbeal9 6/24/2020 12:23:53 PM(UTC)
refrigerator is freezing, freezer seems fine (Refrigerator & Freezer Repair)
by ichellema 8/5/2019 5:05:40 PM(UTC)
GE Refrigerator is freezing fresh food side (Refrigerator & Freezer Repair)
by MikeHam 2/1/2016 7:40:49 PM(UTC)
Electrolux All-Refrigerator is Freezing (Refrigerator & Freezer Repair)
by rousseau 12/1/2015 3:08:31 AM(UTC)
by Jd52981 8/23/2015 5:45:28 PM(UTC)
Refrigerator is freezing food (Refrigerator & Freezer Repair)
by weldmeister 4/14/2014 10:14:26 AM(UTC)
Magic Chef Refrigerator is Freezing everything (Refrigerator & Freezer Repair)
by vincecnj 11/9/2013 8:05:52 AM(UTC)
by blarge 10/15/2012 9:20:28 AM(UTC)
Refrigerator is freezing foods - temp controlls have not been touched in years (Refrigerator & Freezer Repair)
by wmundy 9/14/2012 8:49:20 AM(UTC)
Refrigerator is freezing food in the fresh food compartment (Refrigerator & Freezer Repair)
by KodiakJim37762 5/24/2012 8:29:24 AM(UTC)
Refrigerator is freezing all liquid (Refrigerator & Freezer Repair)
by runaway043 2/25/2012 6:05:26 AM(UTC)
by lspitz 10/5/2011 4:03:21 PM(UTC)
refrigerator is freezing food (Refrigerator & Freezer Repair)
by uptomealso 10/2/2011 7:59:37 AM(UTC)
Refrigerator is freezing foods (Refrigerator & Freezer Repair)
by lrobb 7/27/2011 6:41:24 PM(UTC)
