CindyBehr
#1 Posted : Tuesday, September 30, 2014 8:34:30 AM(UTC)
CindyBehr
There is nothing showing on the touch panel. We turned off the circuit breaker for about 10 minutes and nothing happened when flipped back on. When we open the upper oven door the interior lights for both ovens turn on (but when we open the bottom oven nothing turns on). We can press on the "buttons" and we hear beeps and when we touch light the interior lights come on.
Is this the control board that needs replacing?
#2 Posted : Tuesday, September 30, 2014 9:26:22 AM(UTC)
Parts for Whirlpool RBD305PRS00 Oven - AppliancePartsPros.com
Following is a service manual.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...&id=169;t=1412097524
Yes it does sound like a control board problem.
I would check the control thermal fuse for 0 ohms.
Would also be a good idea to check the primary and secondary resistances of the control transformer.
CindyBehr
#3 Posted : Monday, October 13, 2014 5:18:01 PM(UTC)
CindyBehr
Well, the oven came back on and has worked for a couple of weeks. When it came on error code f2 e5 was showing. My husband pressed buttons (:/) and it has been working since then until tonight. Does it still sound like the control board? Thanks for the help.
#4 Posted : Thursday, October 16, 2014 12:56:41 AM(UTC)
Oops!!
I just noticed that I did not attach the tech sheet.
So will attach it now.
F2E5 is a key/connectioon or a control board problem.
I cannot say which part is the problem.
Unfortunately they do not publish a pin out for the keypad so it is difficult to check.
Perhaps the following will help.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
File Attachment(s):
RBD305.pdf (505kb) downloaded 6 time(s).
CindyBehr
#5 Posted : Friday, October 17, 2014 10:56:02 AM(UTC)
CindyBehr
Thank you. Will try all this before buying the control board.
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by cwsunderland 4/4/2021 5:00:24 AM(UTC)
Whirlpool double oven RBD305PDQ14 (Oven Repair (including Ranges and Cooktops))
by ReeseReed0415 4/21/2020 7:15:22 AM(UTC)
Whirlpool double oven mounted in wall cabinets (Oven Repair (including Ranges and Cooktops))
by Redeyebob 12/30/2019 10:31:52 AM(UTC)
My whirlpool double oven won’t turn on (Oven Repair (including Ranges and Cooktops))
by Zuvdog 12/23/2019 8:38:06 AM(UTC)
Whirlpool Double Oven - Bottom Not Working (Oven Repair (including Ranges and Cooktops))
by kanderna 3/24/2018 9:58:57 AM(UTC)
Dead Display Whirlpool Double Oven (Oven Repair (including Ranges and Cooktops))
by chatenever 12/14/2017 6:51:55 AM(UTC)
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
Whirlpool double oven display blank (Oven Repair (including Ranges and Cooktops))
by krupp 3/26/2016 7:01:29 AM(UTC)
How do I access control panel - Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by technogal54 3/6/2016 8:32:18 AM(UTC)
Whirlpool Double Oven Error Code - Help (E6 F2 and E1 F2) (Oven Repair (including Ranges and Cooktops))
by trvsthbdx 8/24/2015 7:46:08 PM(UTC)
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Whirlpool Double Oven Blank Display (Oven Repair (including Ranges and Cooktops))
by RDLearned 1/26/2015 3:20:49 PM(UTC)
