dragonflies64
#1 Posted : 10 years ago
dragonflies64
Our oven went dead after while using it. The panel, lights everything is dead. The breaker didn't trip either.
Any ideas?
Thank you,
DeeDee
#2 Posted : 10 years ago
I cannot find any info on this unit using the given model number.
Please check it.
First I would check the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next I would check to see if it has a thermal fuse for power to the control board power supply.
This will be a torpedo shaped device in one of the wires close to the control board.
I cannot say if your unit uses this without a model number that I can look up.
If it has one check it with a meter, should be 0 ohms.
dragonflies64
#3 Posted : 10 years ago
dragonflies64
Sorry,
The model number is
RBD305PDQ2
Thank you,
DeeDee
#4 Posted : 10 years ago
Parts for Whirlpool RBD305PDQ2 Oven - AppliancePartsPros.com
There is a thermal fuse in this unit that kills power to the control board etc. (upper left corner of wiring diagram).
If the power is OK then check it.
With the power off to the unit it should be 0 ohms.
It is shown in section 06 towards the bottom of the list (oven thermal fuse).
It will be in one of the wires close to the control board.
If you click on a part's picture or description a new page will open with more info about it.
If it ios blown replace it then check that the oven temperature and oven fan work OK as they may have caused it to blow.
File Attachment(s):
RBD305.pdf (682kb) downloaded 4 time(s).
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 3 years ago
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 7 years ago
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 10 years ago
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 11 years ago
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by abinosa 12 years ago
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 13 years ago
by myoven 13 years ago
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 14 years ago
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 14 years ago
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 15 years ago
by jledereich 15 years ago
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 16 years ago
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 17 years ago
Whirlpool Double Wall Oven - Top Oven Not Working (Oven Repair (including Ranges and Cooktops))
by bigguy 17 years ago
