scooter357
#1 Posted : Tuesday, September 9, 2014 9:23:03 PM(UTC)
scooter357
My GE washer will fill and agitate but will not drain or spin. The timer continues to make the usual clicking noise and advances all the way through the cycle even though nothing is happening. One time I pushed the control knob in to turn it off and the clicking sound continued even with the knob in the off position. Does this sound a lid switch problem or an issue with the timer?
fairbank56
#2 Posted : Wednesday, September 10, 2014 3:33:52 AM(UTC)
fairbank56
Groups: Expert
When agitation stops and it is supposed to go into drain, do you hear any noise from the drain pump? If yes, then there must be a clog or the pump is failing. The washer must be drained before it can spin. If there is no noise from the pump then you need to check for 120vac at the pump wiring terminals. If you have power there, then you need to replace the pump. If no power, then looks like a bad timer. The lid switch is fine or else it would not agitate.
Eric
scooter357
#3 Posted : Wednesday, September 10, 2014 5:11:31 PM(UTC)
scooter357
Eric
Thank you very much. I will check that out and I appreciate your help!
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
