My GE washer will fill and agitate but will not drain or spin. The timer continues to make the usual clicking noise and advances all the way through the cycle even though nothing is happening. One time I pushed the control knob in to turn it off and the clicking sound continued even with the knob in the off position. Does this sound a lid switch problem or an issue with the timer?
Groups: Expert
When agitation stops and it is supposed to go into drain, do you hear any noise from the drain pump? If yes, then there must be a clog or the pump is failing. The washer must be drained before it can spin. If there is no noise from the pump then you need to check for 120vac at the pump wiring terminals. If you have power there, then you need to replace the pump. If no power, then looks like a bad timer. The lid switch is fine or else it would not agitate.
Eric
Originally Posted by: fairbank56  When agitation stops and it is supposed to go into drain, do you hear any noise from the drain pump? If yes, then there must be a clog or the pump is failing. The washer must be drained before it can spin. If there is no noise from the pump then you need to check for 120vac at the pump wiring terminals. If you have power there, then you need to replace the pump. If no power, then looks like a bad timer. The lid switch is fine or else it would not agitate.
Eric Thank you very much. I will check that out and I appreciate your help!
