phillc
#1 Posted : Sunday, August 24, 2014 8:15:40 AM(UTC)
phillc
dishwasher was working fine till the other day then all the lights went out. I checked for voltage at the control panel have 110 volts. power in and out of the door switch,thermal fuse is good, replaced the control panel and no change where do I look next? thank you
#2 Posted : Monday, August 25, 2014 1:30:40 AM(UTC)
Here are your parts.
I think it is a GU2455xtsQ0 not a GU2455xts00
Parts for Whirlpool GU2455XTSQ0 Dishwasher - AppliancePartsPros.com
Sounds more like a control board problem than a control panel (keypad) problem to me.
It is often a gamble as to which of these is causing the problem.
File Attachment(s):
GU2455XT.pdf (244kb) downloaded 25 time(s).
phillc
#3 Posted : Tuesday, August 26, 2014 4:09:47 AM(UTC)
phillc
Sorry the control board is what I already replaced is there any way to check the keypad before replacing it?
#4 Posted : Tuesday, August 26, 2014 4:33:26 AM(UTC)
[COLOR="Blue"]is there any way to check the keypad before replacing it?[/COLOR]
Yes but you need a meter.
Take a look at the tech sheet I attached earlier.
phillc
#5 Posted : Sunday, August 31, 2014 10:47:29 AM(UTC)
phillc
checked out the tech sheet but I don't see what to test to check for the key pad. I checked the fuze, the door switchs and since I already replaced the control board I don't see what else it could be?
#6 Posted : Tuesday, September 2, 2014 9:20:24 AM(UTC)
Sorry for not responding earlier but I was out at the lake.
The keypad check procedure is on Page 2center bottom of the tech sheet.
Note that it only checks the keys.
phillc
#7 Posted : Saturday, September 6, 2014 8:21:05 AM(UTC)
phillc
Thank you test proved it is a bad keypad, again thank you this should make the wife happy:)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
KitchenAid KGRS807SSS02 30" Freestanding Gas Oven Convection - F6 E0 Lost Communications Error (Oven Repair (including Ranges and Cooktops))
by Matthedges 8/9/2022 4:59:40 AM(UTC)
Kenmore 596.72382411 drawer lost power (Refrigerator & Freezer Repair)
by Guest 2/10/2022 4:15:39 PM(UTC)
Magic Chef refrigerator lost its coldness (Refrigerator & Freezer Repair)
by Guest 5/3/2021 12:13:56 PM(UTC)
Help! Tech sheet lost for Kitchenaid refrigerator (Refrigerator & Freezer Repair)
by DANDKB 4/24/2020 11:38:19 PM(UTC)
Bosch dishwasher upper spray arm lost O-rings (Dishwasher Repair)
by Daniel J 2/10/2019 11:56:46 AM(UTC)
Maytag bravos childproof lid key went flying now lost washer wont turn on (Dishwasher Repair)
by Stevethebrain 6/3/2018 6:28:15 AM(UTC)
lost connection for broiler unit (Oven Repair (including Ranges and Cooktops))
by Baughmanc 4/3/2018 12:51:04 PM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
Samsung refrigerator lost all power (Refrigerator & Freezer Repair)
by SueGAK 3/17/2017 8:50:43 AM(UTC)
Lost engagement diamond in machine (Washer Repair)
by watwazat 2/16/2017 7:27:45 PM(UTC)
Whirlpool Front Loader - Lost Wedding Ring! (Washer Repair)
by rockintom 7/4/2016 8:03:03 AM(UTC)
Kenmore Elite Washer lost cycle control (Washer Repair)
by Lion8360 11/23/2015 7:31:56 AM(UTC)
WED9200SQ0 Dryer - Lost Its Mind? (Dryer Repair)
by pahey 9/13/2015 10:30:15 AM(UTC)
Lost items (Washer Repair)
by Noavt 2/13/2014 6:09:55 PM(UTC)
