SunsetSC
#1 Posted : Thursday, August 7, 2014 11:20:40 AM(UTC)
SunsetSC
Hi all, I have a GE front load washer that makes very loud, clunking noises when it goes into the fast spin cycle. I have checked to make sure its level, and it is. The tub appears to be out of balance during the spin. Any suggestions for handyman repair before I call a service provider? Thanks in advance.
brobriffin
#2 Posted : Thursday, August 7, 2014 4:43:12 PM(UTC)
brobriffin
Man
United States
Please post model number of unit
SunsetSC
#3 Posted : Friday, August 8, 2014 10:24:05 AM(UTC)
SunsetSC
GE model WBVH6240
brobriffin
#4 Posted : Friday, August 8, 2014 5:49:24 PM(UTC)
brobriffin
Man
United States
There are four shock absorbers on the bottom of the drum.
Part number WH01X10343 see page
Parts for WBVH6240 - AppliancePartsPros.com
These shocks tend to wear out rather quickly. This should stabilize the drum during spin as well as during agitate.
At first glance the old ones may appear ok however they are only made of plastic and loose the ability to DAMPEN the movement of the drum correctly over a period of time, especially if you routinely wash large or heavy loads.
Also if your not sure how to change them click the video link on the order page and watch Matt change one.
{Added thought} I would recommend changing all 4 shocks I tried changing just the one I thought to be bad and wound up repeating the repair to replace the remaining ones the following week.
brobriffin
#5 Posted : Friday, August 8, 2014 5:58:23 PM(UTC)
brobriffin
Man
United States
One final thought, check to make sure the suspension springs are still attached at the top of the drum. In a rare case I've seen one pop off during spin when the drum was shacking violently.
Guest (4)
Washer spin cycle problem (Washer Repair)
by td307 12/30/2015 11:17:13 AM(UTC)
Spin Cycle Problems (Washer Repair)
by btmullaney 11/21/2014 5:10:45 AM(UTC)
GE Spacemaker spin cycle problems (Washer Repair)
by Kristal9 6/16/2013 8:17:51 AM(UTC)
Spin cycle problem (Washer Repair)
by akchad 11/12/2012 10:40:12 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
May tag washer spin cycle problem (Washer Repair)
by C.ketcham 10/14/2012 10:38:06 AM(UTC)
Maytag spin cycle problem (Washer Repair)
by WmPilacinski 7/31/2012 6:50:31 PM(UTC)
Kenmore spin cycle problem (Washer Repair)
by 1jimbo 2/1/2012 2:49:45 PM(UTC)
Whirlpool Washer Spin Cycle Problem (Washer Repair)
by rbyeway 11/8/2011 7:49:07 AM(UTC)
by Amy Pirrone 8/24/2011 8:36:34 AM(UTC)
by discher 2/23/2011 4:14:36 PM(UTC)
Kenmore Spin Cycle problems (Washer Repair)
by mmerr 1/29/2011 7:48:04 AM(UTC)
Kenmore Direct Drive Washer Spin cycle problem (Washer Repair)
by rocky03 1/11/2011 2:01:52 PM(UTC)
GE Washer Spin Cycle Problems (Washer Repair)
by jodava 5/19/2010 1:08:39 PM(UTC)
by Andy52 1/26/2010 3:48:03 PM(UTC)
