Hi I have a top freezer gold whirlpool refrigerator, the water dispenser stop working. I replaced the water inlet valve but it still not working.
Perhaps your water tube in your fridge door is frozen. I would check this first. If this is the case, then the water would not be able to pass through. To check this find the beginning of the tube on the door. Disconnect it and blow into it. If the air passes through then this is not the problem.
