Ken622
#1 Posted : Friday, June 20, 2014 9:40:32 PM(UTC)
Ken622
Freezer running at 30 degrees, fresh food at 40 degrees. Notice a few days ago ice cream soft. Removed evaporator panel. Checked for frost conditions, defrosted with hairdryer. Used compressed air to clean DC fan & compressor.Checked motherboard for Ohm readings at J1 of harness for all temp sensors. Ohm readings were between 16.3 Ohms +- 5 Ohms after putting temp sensors in cup of ice water for 5 minutes. Later plugged unit back on for 1 hour, checked evaporator lower 4 coils frosted over. Evaporator & compressor running continuously. Lowered temp selector from 9 to 8 unit shut down defrost heater came on, only problem freezer temp went up. My question is more of probably. I have come up a few conclusions. 1# bad compressor, 2# faulty motherboard & evaporator fan or 3# a small in my sealed system. Mean while I have a frig without a freezer.
#2 Posted : Saturday, June 21, 2014 1:49:31 AM(UTC)
If you defrosted the evaporator and the compressor runs constantly and the condensing fan motor runs, you have a refrigerant leak/ damaged compressor.
GE fridge with bottom freezer running warm (Refrigerator & Freezer Repair)
by Annorax 8/1/2014 12:45:29 PM(UTC)
Upright Freezer Running Warm (Refrigerator & Freezer Repair)
by RedTrex 9/30/2013 3:36:07 PM(UTC)
Fridge AND Freezer running warm (Refrigerator & Freezer Repair)
by BrianScottMoore 11/24/2011 9:40:07 PM(UTC)
by BrianScottMoore 11/24/2011 9:39:36 PM(UTC)
