Jim N
#1 Posted : Thursday, December 13, 2007 5:45:44 AM(UTC)
Jim N
My dryer was not heating. I found the heating element and the jumper wire were "broken" at the terminal. I replaced the complete heater assembly and jumper wire. The dryer will not run at all now. It "hums". Do I have it wired wrong? Is there a wiring diagram somewhere or do i need to replace the high limit thermostat or the fuse?
kawfeeman
#2 Posted : Thursday, December 13, 2007 8:05:34 PM(UTC)
kawfeeman
if you have a second person to help, leave drum door open and have someone depress the start button on control panel, while you depress the door switch and then try to push the paddle / baffle of drum clockwise.. if the drum turns on its own, you are getting / have a bad motor ( hopefully you did not wire anything wrong when you replaced the heater / jumper wires.. )
Jim N
#3 Posted : Friday, December 14, 2007 9:37:33 AM(UTC)
Jim N
No, the motor is OK. If I connect both wires to the same terminal of the heating element, the dryer runs - no heat. I checked continuity thru the stat, the fuse and the heating element.
Jim N
#4 Posted : Friday, December 14, 2007 9:47:34 AM(UTC)
Jim N
Maybe I connected wiring wrong? I connected purple wire from low-limt stat to hi-limt stat; white jumper from hi-limit stat to one heating element terminal; black wire from other heating element terminal to motor.
Guest (4)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Maytag Dryer not heating up properly (Dryer Repair)
by BobG68 10/23/2011 11:45:22 PM(UTC)
by dee2011 7/5/2011 9:02:29 AM(UTC)
Maytag Dryer not heating (Dryer Repair)
by drs1023 5/23/2011 8:55:33 AM(UTC)
Maytag Dryer not heating well (Dryer Repair)
by indiana324 5/14/2011 11:52:25 AM(UTC)
Maytag dryer not heating properly (Dryer Repair)
by vpolitano 1/18/2010 9:37:23 PM(UTC)
by al todd 1/16/2010 2:23:00 PM(UTC)
Maytag dryer not heating, burned wires (Dryer Repair)
by cmorgand 1/5/2010 2:08:06 PM(UTC)
by bytor 1/22/2009 6:59:50 PM(UTC)
Maytag dryer not heating. (Dryer Repair)
by elkski 10/25/2007 7:57:18 AM(UTC)
Maytag dryer not heating up on all cycles and not properly drying clothes. (Dryer Repair)
by radioman464 10/15/2007 12:36:28 PM(UTC)
