Dana021
#1 Posted : Monday, April 28, 2014 5:05:18 PM(UTC)
Dana021
My workhorse of a washer has stopped spinning. It fills, agitates, and drains swimmingly, but after taking the front panel off, makes a 1/2 inch attempt at a spin, but does not complete a rotation or start to spin. If I shake the drum it will make a few rotations, but won't complete the spin cycle. Water level is fine, timer seems to work, because after what would appear to be a normal spin cycle, the washer shuts off or continues for another rinse (as instructed)
Should I just replace the control panel or is there anything else I've missed.
fairbank56
#2 Posted : Tuesday, April 29, 2014 4:22:29 AM(UTC)
fairbank56
Groups: Expert
What is the motor pulley doing when in spin mode? Is it rotating ok but belt is not (slipping)? Does large pulley rotate? With washer off, rotate motor pulley in spin direction by hand. Use two hands to keep it going as brake will stop it right away if you don't keep it moving. Does main pulley and transmission rotate while doing this?
Eric
Dana021
#3 Posted : Tuesday, April 29, 2014 4:36:12 AM(UTC)
Dana021
Im not sure if i know which is moving, but when i rotate it by hand, the drum spins.
Dana021
#4 Posted : Tuesday, April 29, 2014 8:32:41 AM(UTC)
Dana021
After screwing around with it, it appears that it will randomly try and spin and somewhat succeed for a minute or so (sounds slow and unbalanced, but displaces clothes enough to look spun). When it stops spinning, opening and closing the lid a handful of times will launch it into its pathetic short-lived spin. I've already ordered a control panel, but just want to know if theres anything else i'm missing.
Guest (4)
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 12/27/2015 12:35:03 PM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin during final rinse (Washer Repair)
by Asu19 10/28/2015 2:38:21 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE Washer Won't Spin - Lid Lock Error? (Washer Repair)
by lum 1/30/2014 11:41:30 PM(UTC)
GE Washer won't spin dry clothes (Washer Repair)
by jglascoe1691 12/10/2013 4:41:11 AM(UTC)
GE washer won't spin/agitate (Washer Repair)
by Mlsmith 10/8/2013 5:30:10 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
GE washer won't spin - Mark (Washer Repair)
by masavrin@netzero.net 1/2/2013 9:45:50 AM(UTC)
GE washer won't spin (Washer Repair)
by the5tjrs 11/2/2012 9:01:04 AM(UTC)
GE Washer won't spin with heavy loads (Washer Repair)
by paulgj 10/18/2012 8:00:50 PM(UTC)
ge washer won't spin (Dishwasher Repair)
by magsw 5/24/2012 3:12:19 PM(UTC)
ge washer won't spin or wash, no blinking lights on motor (Washer Repair)
by fr45 2/28/2012 9:22:19 AM(UTC)
GE Washer won't spin but agitates (Washer Repair)
by guptamgs@hotmail.com 1/5/2012 11:29:15 AM(UTC)
GE washer won't spin unless i give it a hand. (Washer Repair)
by nannerz11 12/15/2011 1:01:23 PM(UTC)
