The fan inside the freezer doesn't come on when the condenser does at times. A service tech looked at it and told me the main board was going bad. He also showed me that I could unplug it for a minute or so and it would reset it and it would run. That has been working but, the problem is getting worse so I bought a new board. After installing the new board the fan is doing the same thing. Any ideas? Thanks.
Update to this. The fan never came back on with the new board. I put the old board back in and the fan came on. I do still have to unplug the fridge from time to time to make the fan come back on.
