cover
#1 Posted : Thursday, May 21, 2015 6:47:34 PM(UTC)
cover
I have a model 25326442100 that just stopped cooling properly. Any pointers on where to start from a troubleshooting standpoint?
It seems to run fine and the back panel is cool as I reach back with the door open and touch it, LED controller appears to range through the 0-7 range okay (though I haven't tried dropping it to zero). It normally ran fine on a setting of 3 and just suddenly took a turn for the worse. I've tried unplugging it and plugging it back in a few minutes later to see if perhaps something electronic would reset but no luck.
About 2 years ago, I replaced a 297054500 'Relay' that was mounted on the compressor motor as I recall and I guess have to wonder if that may be acting up again.
Thanks for any advice...
#2 Posted : Thursday, May 21, 2015 11:43:38 PM(UTC)
Need more info on the symptoms.
Is the compressor running?
You can usually hear it but should also be able to feel it vibrating.
Does it cycle on/off or is never on or is on all the time except when the unit goes through a defrost cycle?
If the evaporator fan on?
Have you checked the evaporator coils for frost pattern?
