Freezer is set on 9 but ice cream is mushy. Other items, vegies, etc. are barely frozen. Problem is worse on warm humid days. Frig tends to freeze foods even when set on 5-6. Have removed the back panel in freezer and removed ice build-up on the right around the sensor. Also, vacuumed the coils and compressor.
Originally Posted by: danno621  Freezer is set on 9 but ice cream is mushy. Other items, vegies, etc. are barely frozen. Problem is worse on warm humid days. Frig tends to freeze foods even when set on 5-6. Have removed the back panel in freezer and removed ice build-up on the right around the sensor. Also, vacuumed the coils and compressor. Try to set the freezer control on 8 and the refrigerator control on 2. Wait about 24 hours to see the result. Gene.
