replaced ignitor,coils and flame sensor,and still no heat please help:)
Hi
Open it up again and test all of the thermal fuses and thermostats for continuity using a meter. You will probably find one with an open circuit, and if you do replace it.
If not, post the results and let's see what else it might be.
thank you for your answers changed thermal fuse and dryer cycling thermostat it worked:) :) :)
Great, and thanks for updating us.
