proturf
#1 Posted : Tuesday, April 1, 2014 2:12:21 PM(UTC)
proturf
I have a Whirlpool TAWS700EQ2 machine. The plastic spin gear in the transmission is stripped. The replacement gear (w/metal pinion gear) is rather expensive $60-$70 (AP3094405) and what I am wondering if a more economical kit (neutral drain kit) 388253, which is listed many places on line for $15-$25 range, will kit my transmission?
mr_mjsjr
#2 Posted : Tuesday, April 1, 2014 3:26:21 PM(UTC)
mr_mjsjr
there is a neutral drain kit listed on this site that would fit your unit, but it does not contain the spin gear you need. i wouldn't think any others would either, because the neutral drain merely engages or disengages the spin bearing; thus being separate.
proturf
#3 Posted : Tuesday, April 1, 2014 3:40:21 PM(UTC)
proturf
The link to this neutral drain kit is here.... it shows the gear included....
http://www.amazon.com/388253-GE...AP3094405#productDetails
mr_mjsjr
#4 Posted : Tuesday, April 1, 2014 3:58:54 PM(UTC)
mr_mjsjr
that should work just fine, but the fine people putting this site together may feel slighted with the posting of a competitor site after asking there expertise.
proturf
#5 Posted : Tuesday, April 1, 2014 5:27:55 PM(UTC)
proturf
Oh, I guess I did not understand that this was a commercial site.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
