alicehec@aol.com
#1 Posted : Tuesday, March 25, 2014 6:04:29 PM(UTC)
alicehec@aol.com
Oven will not heat after the cleaning cycle. I have replaced Thermostat and Sensor Probe Still element is just barely warm. What is the next thing to replace?
#2 Posted : Wednesday, March 26, 2014 3:34:53 AM(UTC)
Parts for Whirlpool KEBC147VBL02 Wall Oven - AppliancePartsPros.com
See the attachment for your tech sheet.
[COLOR="Blue"]
By "thermostat" do you mean the thermal fuse?
Still element is just barely warm.[/COLOR]
Which element?
[COLOR="Blue"]
What is the next thing to replace?[/COLOR]
You have to do more troubleshooting.
Do you have a meter and if yes do you know how to use it?
File Attachment(s):
KEBC147.pdf (584kb) downloaded 4 time(s).
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by Rocky D 1/19/2023 5:12:04 PM(UTC)
KitchenAid Oven KEBS107SBL (Oven Repair (including Ranges and Cooktops))
by PapaThor 10/20/2021 12:10:45 PM(UTC)
KitchenAid oven doesn't get up to temperature (Oven Repair (including Ranges and Cooktops))
by mlaird 12/27/2019 7:29:00 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
kitchenaid oven (Oven Repair (including Ranges and Cooktops))
by ttrueheart 3/25/2018 2:59:31 PM(UTC)
How to reinstall KitchenAid oven door (Oven Repair (including Ranges and Cooktops))
by tiggers13 1/18/2017 1:31:44 PM(UTC)
KitchenAid Oven, intermittent lighting (Oven Repair (including Ranges and Cooktops))
by ryancfields 3/27/2016 8:15:32 AM(UTC)
KITCHENAID OVEN DOES NOT LIGHt (Oven Repair (including Ranges and Cooktops))
by PCircenis 1/22/2016 8:17:28 AM(UTC)
Kitchenaid Oven Help (Oven Repair (including Ranges and Cooktops))
by ehenry 12/9/2015 3:59:14 PM(UTC)
kitchenaid oven no power and locked (Oven Repair (including Ranges and Cooktops))
by greg_gue 1/12/2015 12:50:02 PM(UTC)
Kitchenaid oven keeps shutting OFF (Oven Repair (including Ranges and Cooktops))
by jbili 10/16/2014 3:37:51 PM(UTC)
KitchenAid Oven F1 E1 error (Oven Repair (including Ranges and Cooktops))
by bobu2 1/4/2014 4:39:33 PM(UTC)
KitchenAid Oven Won't Hold Temp (Oven Repair (including Ranges and Cooktops))
by bjjansen 1/2/2014 6:19:08 AM(UTC)
Recurring Kitchenaid oven hinge failure (Oven Repair (including Ranges and Cooktops))
by walterjdog 12/18/2013 3:03:08 PM(UTC)
