islanbplumb
#1 Posted : 11 years ago
islanbplumb
hi,
my gas dryer dosen't shut off when on auto cycle, but works fine on timed setting. what is the part that i need to order?
islanbplumb
#2 Posted : 11 years ago
islanbplumb
well not sure if its more then 10 years old. i just had to change the belt. and the next day, this was the problem.
fairbank56
#3 Posted : 11 years ago
fairbank56
Groups: Expert
This is an 02 model. Does timer advance at all in auto dry or just not advancing to OFF when it gets to end of cycle? Is it drying clothes in normal amount of time? If timer doesn't advance at all in auto dry, you probably just need to clean the moisture sensing bars. If it does advance but stops short of going into OFF position, timer is bad.
Eric
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 9 months ago
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 10 months ago
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 10 months ago
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 10 months ago
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 11 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 12 months ago
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest about a year ago
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 about a year ago
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B about a year ago
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 2 years ago
Drum repair of old Speed Queen gas dryer (Dryer Repair)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
