hi,
my gas dryer dosen't shut off when on auto cycle, but works fine on timed setting. what is the part that i need to order?
well not sure if its more then 10 years old. i just had to change the belt. and the next day, this was the problem.
Groups: Expert
This is an 02 model. Does timer advance at all in auto dry or just not advancing to OFF when it gets to end of cycle? Is it drying clothes in normal amount of time? If timer doesn't advance at all in auto dry, you probably just need to clean the moisture sensing bars. If it does advance but stops short of going into OFF position, timer is bad.
Eric
