I have a whirlpool all refrigeratorwhich is blowing warm air. The compressor is vabrating when the power is on (looks like working). what can i do to get working right? how to identify if it is seal problem? Please help.
Check to see if the condenser fan at the back underneath the fridge is running. It should be running. Is the compressor motor near that fan running. Are the coils warm ,cold or hot. Should be warm.
Is the evaporator fan in the freezer running. It should be running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere. should be lightly frosted.
Check to see if the condenser fan at the back underneath the fridge is running. It should be running. – No Fan Is the compressor motor near that fan running. – The motor is vibrating, looks running. Are the coils warm ,cold or hot. Should be warm. – The coil is cold
Is the evaporator fan in the freezer running. It should be running. – This unit is refrigerator only, no Freezer. Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere. should be lightly frosted. – Clear. May be due to it has been warm for 2 days. Can you please give me further idears? Thanks
With the compressor running and the condenser coils not warm, either the compressor is bad or low on freon. Tech needed.
