paulli
#1 Posted : Tuesday, May 5, 2009 11:42:10 AM(UTC)
paulli
I have a whirlpool all refrigeratorwhich is blowing warm air. The compressor is vabrating when the power is on (looks like working). what can i do to get working right? how to identify if it is seal problem? Please help.
woodchuckie
#2 Posted : Tuesday, May 5, 2009 1:02:12 PM(UTC)
woodchuckie
Check to see if the condenser fan at the back underneath the fridge is running. It should be running.
Is the compressor motor near that fan running.
Are the coils warm ,cold or hot. Should be warm.
Is the evaporator fan in the freezer running. It should be running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere. should be lightly frosted.
paulli
#3 Posted : Tuesday, May 5, 2009 1:13:44 PM(UTC)
paulli
Check to see if the condenser fan at the back underneath the fridge is running. It should be running. – No Fan
Is the compressor motor near that fan running. – The motor is vibrating, looks running.
Are the coils warm ,cold or hot. Should be warm. –
The coil is cold
Is the evaporator fan in the freezer running. It should be running. –
This unit is refrigerator only, no Freezer.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere. should be lightly frosted. –
Clear. May be due to it has been warm for 2 days.
Can you please give me further idears?
woodchuckie
#4 Posted : Tuesday, May 5, 2009 1:54:50 PM(UTC)
woodchuckie
With the compressor running and the condenser coils not warm, either the compressor is bad or low on freon. Tech needed.
Freezer working, refrigerator warm (Refrigerator & Freezer Repair)
by Hero 12/31/2021 6:48:52 AM(UTC)
Refrigerator warm 45 degrees , freezer gets very cold then warms up (Refrigerator & Freezer Repair)
by sgordonson 9/25/2020 7:31:42 AM(UTC)
Refrigerator warm, freezer cold, frost buildup on back of freezer (Refrigerator & Freezer Repair)
by Geoff Hess 8/15/2017 8:31:32 AM(UTC)
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9/7/2016 6:50:59 PM(UTC)
Electrolux - refrigerator warm - freezer good - cooling drawer good (Refrigerator & Freezer Repair)
by smnorrick 2/5/2016 11:22:03 AM(UTC)
Refrigerator warm and cold (Refrigerator & Freezer Repair)
by David T 7/16/2015 10:29:23 AM(UTC)
Freezer defrosts and refrigerator warms (Refrigerator & Freezer Repair)
by problems 11/10/2014 4:40:42 PM(UTC)
Freezer Cold Refrigerator Warm - Evap Fan Runs Intermittently (Refrigerator & Freezer Repair)
by Mkorns 5/27/2014 10:52:33 AM(UTC)
Refrigerator Warm / Freezer Cold (Refrigerator & Freezer Repair)
by lukewarm 11/1/2013 9:21:13 AM(UTC)
GE Freezer and refrigerator warm, frost on coils-what should an amateur change first? (Refrigerator & Freezer Repair)
by dfavelo 10/2/2013 6:55:19 PM(UTC)
Freezer seems fine, refrigerator warm, found frost on return vent at top (Refrigerator & Freezer Repair)
by Cczkcb 10/1/2013 2:42:34 AM(UTC)
Refrigerator warm Freezer ok (Refrigerator & Freezer Repair)
by larbear 8/24/2013 7:24:21 PM(UTC)
Refrigerator Warm Light not working (Refrigerator & Freezer Repair)
by blueeyes243 4/15/2013 7:07:22 AM(UTC)
Refrigerator warm, coils frozen solid (Refrigerator & Freezer Repair)
by tom1799 9/12/2012 8:13:10 AM(UTC)
Refrigerator warm, freezer fine. (Refrigerator & Freezer Repair)
by gandswalton 9/2/2012 1:34:35 PM(UTC)
