dshoff
#1 Posted : Wednesday, January 8, 2014 6:04:22 AM(UTC)
dshoff
[FONT="Arial Black"][/FONT] can anyone tell me how to test the run capacitor
it is part# 55 on system diagram after reading allot of your blog we're pretty sure or at least praying that the problem is either the relay switch or compositor & with money being so tight only have the money to purchase 1 right now it was working exelent then wife filled it and the vacuum sound that it always did as soon as door shut and noticed that a couple of the pizzas defrosted so we remove and rearranged the food inside for better air flow vacuum sound didn't come back but it did cool down for about a wk then it just stopped cooling at all hoping to fix cheep
#2 Posted: : Thursday, January 9, 2014 11:00:17 AM(UTC)
http://www.appliancepartspros.c...ch.aspx?model=FFU21C4cw1
Here is the wiring diagram
http://manuals.frigidaire.com/p...df/StCloud/216803200.pdf
Here is a site with info on testing components.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note that neither the compressor or the capacitor tests are definitive.
In other words if the part fails the test it is bad but if it passes the test it does not mean that it is good. In the case of the capacitor it may only fail when full working voltage is applied to it.
If the start relay is getting 120 volts then it is a more likely suspect.
I am assuming that the problem is that the compressor gets voltage but does not run.
If it does not get voltage then the problem may be the control thermostat.
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Cafe induction range issue... Help please! (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2023 7:31:31 PM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Help please (Oven Repair (including Ranges and Cooktops))
by wolfmanTX 11/2/2017 10:55:06 AM(UTC)
Dryer help please (Dryer Repair)
by Juliebolson 5/30/2017 12:34:48 AM(UTC)
by Jenjudd2 7/1/2015 3:18:27 PM(UTC)
Whirlpool fridge help please (Refrigerator & Freezer Repair)
by The Hurricane 3/25/2015 5:35:41 PM(UTC)
Newbe - Refrig/Freezer Help Please596.50694000 (Refrigerator & Freezer Repair)
by rodnogdog 2/22/2015 7:53:20 AM(UTC)
~*~Help please. Amana20 Cool not Cold. Any trouble shooting tips please~*~ (Refrigerator & Freezer Repair)
by PeterB. 9/2/2014 3:18:01 AM(UTC)
~*~Newbie. Could use some help please~*~ (Washer Repair)
by PeterB. 6/20/2014 6:57:51 AM(UTC)
Water Dispenser Sticks in On Position! Help Please? (Refrigerator & Freezer Repair)
by crosby1 3/16/2014 12:24:58 PM(UTC)
Whirlpool washer help please (Washer Repair)
by jcnitram 1/16/2014 7:10:15 PM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
by sheriowaso 11/15/2013 4:21:37 PM(UTC)
Oven bake will not come on!Help please (Oven Repair (including Ranges and Cooktops))
by dwelsher 3/12/2013 7:33:36 PM(UTC)
