3 Pages<123>
Eda524eda
#11 Posted : Tuesday, December 4, 2012 4:59:02 AM(UTC)
Eda524eda
GREAT advice. Pushed screen aside; it was clogged. Shame on GE for design that is sure to fail. Thanks for info.
efroun
#12 Posted : Wednesday, December 26, 2012 9:23:05 AM(UTC)
efroun
This is a great site and thanks a million to the original poster who asked the question and also the poster who provided the excellent answer! I shudder to think of all of the people that have paid hundreds for service calls to repair something so simple that was caused by a poor design.
This applies at least to the following GE built-in oven models: JKP15, JRP15, JTP15.
I discovered the problem when I got the F2 error during the first time I ever utilized the self cleaning function. Obviously the extreme temperature of the oven during this operation created a large amount heat behind the control panel that the fan could not remove due to the blocked filter.
In addition, the control panel fan has been running for hours longer than it should every time I used the oven for about 10 years! Per the answer that was given, I removed (tore out) the fan filter completely.
Looking forward to enjoying the greatly reduced fan run times!
ANRN
#13 Posted : Wednesday, February 13, 2013 11:26:47 AM(UTC)
ANRN
Just found this website and what has been described previously is exactly what i have been experiencing with my oven! My husband took off control panel and the screen was covered in dust. I have high hopes that this will fix the problem!
teerose
#14 Posted : Thursday, February 14, 2013 2:11:46 PM(UTC)
teerose
I have the same issue with f2 error. The oven is locked flashing f2 fau le and i cant turn off the oven. Any advice?
MegaMelon
#15 Posted : Thursday, December 26, 2013 7:30:44 PM(UTC)
MegaMelon
Wow. Please add me to the list of folks offering a big "thank you" for the info in this thread. I'm hardly a handyman, but this was an easy fix. Thanks again.
shanewoods21
#16 Posted : Monday, December 30, 2013 11:35:49 PM(UTC)
shanewoods21
Originally Posted by: olean Go to Quoted Post
[COLOR="Black"]I have a built in Ge oven JTP15BW2BB purchased in 1998. When I try to use the self[/COLOR] [COLOR="Black"]bond cleaners gold coast[/COLOR][COLOR="Black"] I get a code "F2" after 1 hour. I have to turn the breaker off for a while for it to clear. I don't know if it would be worth it to call a repair man and my husband is a great handy man and an electrician so I am sure he could fix it if I can tell him what to look for. All else on the oven works just fine. Can you help[/COLOR]?
Hello friend were you able to sort out the F2 error problem while cleaning oven? I am facing similar problem so can you share some information to help me out? Waiting for reply
cripes
#17 Posted : Sunday, January 4, 2015 5:54:19 PM(UTC)
cripes
Haven't been able to use the self cleaning feature for years. When I first got the F2 code, I did a Google search and "bad heat sensor" came up. Thinking service call and big money, I didn't do anything. Recently, I read your solution. Within about 5 minutes and following your directions, I was able to remove the clogged screen and the self cleaning feature is working correctly. Thank you!
perry85
#18 Posted : Wednesday, October 21, 2015 3:47:32 AM(UTC)
perry85
I have the same type of stove with the same issue but cannot seem to find the fan. Am I missing something? Please help.
lcris
#19 Posted : Thursday, March 2, 2017 9:21:36 AM(UTC)
lcris
Originally Posted by: abadfish66 Go to Quoted Post
Behind the control panel is a cooling fan. Either the cooling fan is not working, or (most likely) the screen behind the fan is clogged with dust... F2 during clean is an over heat error in the control panel section. You can remove the control panel by removing the 3 screws under the panel, then lift up and off....Make sure you turn the breaker off first...
I was able to remove the control panel and can see the screen behind the fan is totally clogged. How do you remove the screen? the fan is bolted to the back of the panel and the screen is behind the fan. Thanks for your help!
lcris
#20 Posted : Thursday, March 2, 2017 9:25:10 AM(UTC)
lcris
How did you remove the screen? Its behind the fan and the fan is bolted to the back of the oven.
3 Pages<123>
