timr75-143
#1 Posted : Tuesday, December 3, 2013 5:16:11 PM(UTC)
timr75-143
hello, i have a whirlpool oven. there are no error codes on the clock thing, but.... my bake a broil functions are not working correctly. If I unplug the unit for a bit then plug it back in, the bake element(or broiler) will come on and get up to temperature. But if i open the door and let it cool for a bit the elements will not come back on even if i try to preheat to a higher temp. or put broil on after bake. i have replaced the temp sensor but nothing else also the old sensor was reading 1080 ohms. Any advice would be great, Thank you.
#2 Posted : Wednesday, December 4, 2013 1:23:26 AM(UTC)
Parts for Whirlpool RF214LXTQ0 Range - AppliancePartsPros.com
Sounds like the control board is bad.
It is not regulating the temperature correctly.
The reason the unit works if you unplug it, is that unplugging it resets the board.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 5/21/2024 3:00:41 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
