Originally Posted by: Appliance Ninja Okay, so we need to determine if that power is getting out of the switch to the control. Can you press the plunger on the switch and measure for power at the control? There is power with the plunger in either position. I am touching the red wire to another post. Is that right since I only have a circuit tester?
So you are showing power at the control?
Originally Posted by: Appliance Ninja So you are showing power at the control? Yes, power at the door latch and power where that wire attaches to the control panel.
Originally Posted by: Appliance Ninja How difficult is switching them out?
It will just unplug from the control, very easy.
Originally Posted by: Appliance Ninja It will just unplug from the control, very easy. Thank you very much. I know it took a while.
It was my pleasure to help, you are very welcome. Have a great evening!
I finished installing part "Whirlpool 6-917723 Panel-con" on my Jenn-Air dishwasher and it seems to want to work but when I touched "normal wash and start" it just blinked. What did I do wrong?
