Refrig and freezer go warm randomly, food in freezer thaws, food in refrig warms to room temp. Can wait day, restart, OK for week or few days, then warm again. This is a smaller refrig downstairs, light usage. Wouls appreciate possible problem, parts replacement. Thanks, Steve.:confused:
The thermostat is most likely intermittent. Next time it stops cooling, tap on the control knob with a screwdriver handle and see if it turns on. If it starts to work, that thermostat is bad. However, that part is not available as a replaceable part. There is a generic that will work, though, available below. Pro TJ90SC1002 Universal Cold Contro - AppliancePartsPros.com
:) Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The thermostat is most likely intermittent. Next time it stops cooling, tap on the control knob with a screwdriver handle and see if it turns on. If it starts to work, that thermostat is bad. However, that part is not available as a replaceable part. There is a generic that will work, though, available below. Pro TJ90SC1002 Universal Cold Contro - AppliancePartsPros.com Thanks for the info and part number, I will try tapping on the control knob the next few times it occurs, and buy the part if that is the solution. Steve
You are very welcome, let me know how it goes! That thermostat is one that is mounted to the interior cabinet, so you will have a little plastic box in the cabinet, just so you know.
