2 Pages12>
melavid
#1 Posted : Monday, November 18, 2013 3:23:26 PM(UTC)
melavid
Hi, I had a backed up lint trap, cleaned it out and now the dryer has no heat and runs then shows AD. I did the the error codes test and these are the codes I got.
FLD r06
E04
FLD E56 025
C01 00 165
101 FLD 139
076 FLD
FLD.
Do you know what the problem is? I already reset my home breaker and unplugged the dryer and plugged it back in and did a reset.
Appliance Ninja
#2 Posted : Monday, November 18, 2013 5:50:56 PM(UTC)
Appliance Ninja
The "ad" in the display simply means it is in an Auto Dry cycle. I suspect you have an open thermal fuse if the vent was restricted. Do you have a meter to test continuity with?
#3 Posted : Tuesday, November 19, 2013 3:04:42 AM(UTC)
Parts for Frigidaire AEQ7000ES1 Dryer - AppliancePartsPros.com
I cannot find any info on the given E codes.
If the given E56 is actually an E5B then this is just a no heat error which you already know.
Here is the tech sheet
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
I doubt it is the thermal fuse as it looks like if the thermal fuse blew the motor would not run on this unit.
I would start by checking the power to the unit. the control board and motor run off of 120 volts but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK then unplug the unit and check the heating coil and then the hi-limit thermostat with a meter. Note that if the high limit is blown be sure to check that the heating element is not grounded. Also check the thermistor just to be sure that it is OK.
Below is a link to a service manual which may come in handy. You will have to join the site to be able to download manuals.
http://appliancejunk.com...&id=259;t=1384861237
melavid
#4 Posted : Tuesday, November 19, 2013 8:48:12 AM(UTC)
melavid
Hi, I don't have a way to check the voltage. I'm going to try replacing the heating coils. I hope that's all it is.
Appliance Ninja
#5 Posted : Tuesday, November 19, 2013 8:55:28 AM(UTC)
Appliance Ninja
The heating element is available below.
http://www.appliancepartspros.c...131553900-ap2107129.html
melavid
#6 Posted : Tuesday, November 19, 2013 9:02:02 AM(UTC)
melavid
its a dryer
Appliance Ninja
#7 Posted : Tuesday, November 19, 2013 9:10:14 AM(UTC)
Appliance Ninja
Yes, the post above has the link to the heating element. I have moved it to below, too.
Frigidaire 131553900 Dryer Heating Element Assembly - AppliancePartsPros.com
#8 Posted : Tuesday, November 19, 2013 9:48:17 AM(UTC)
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
melavid
#9 Posted : Tuesday, November 19, 2013 5:29:00 PM(UTC)
melavid
Thanks,I replaced heating element, it was burnt and broken, but still no heat and dryer runs and then says add after running for a bit. I guess I need a tester to test the other parts listed.:confused:
Appliance Ninja
#10 Posted : Wednesday, November 20, 2013 8:22:21 AM(UTC)
Appliance Ninja
The L1 side of the voltage to the element comes from the control, through the high limit thermostat and to the heater. The L2 side comes from the motor. So, if you have proper power supply voltage, one of those three components is likely faulty. You may have luck turning the breaker totally off then back on as when the element shorted, it may have tripped the L2 side of the supply. If still no heat, you will need a meter to test voltage with.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
2 Pages12>
