hvff0572
#1 Posted : Sunday, November 17, 2013 12:43:06 PM(UTC)
hvff0572
ok so i have a whirlpool top load dryer that wont drain the water and stops before it gets to the rinse or the spin cycle. this all started when i put a couple of really heavy blankets in it. i think it may be the belt but am unable to get the back off to look for some reason. i was able to drain the water tho. the model # is LSR5132JQ1. I would appreciate any help yall can provide. Thank you.
fairbank56
#2 Posted : Sunday, November 17, 2013 2:02:25 PM(UTC)
fairbank56
Groups: Expert
This is a direct drive model, no belts. You don't take the back off, you would remove the cabinet to gain access or tilt the machine back. After agitation stops and it should start draining, does the motor run or hum or is it all quiet? If all quiet, sounds like a bad lid switch. If motor hums but won't drain, probably something jamming the water pump.
Eric
hvff0572
#3 Posted : Sunday, November 17, 2013 5:42:59 PM(UTC)
hvff0572
the motor hums when its going. this is something it has never done before. could you tell how to open the cabinet? im not exactly sure where that is located.
fairbank56
#4 Posted : Monday, November 18, 2013 4:29:40 AM(UTC)
fairbank56
Groups: Expert
How to Disassemble Whirlpool/Kenmore Direct Drive Washer - YouTube
Pump is on back of motor. Release the two spring clips to pull it off from motor.
Eric
Whirlpool top load washer Model # WTW58ESVW quit working (Washer Repair)
by chuck gibson 3/12/2021 4:37:30 PM(UTC)
Help needed - Whirlpool top load washer (Washer Repair)
by lediaz 1/18/2019 8:18:13 AM(UTC)
Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves (Washer Repair)
by Girliemom21 7/18/2017 5:57:17 AM(UTC)
Whirlpool top load washer out of balance (Washer Repair)
by gvanzant1 12/3/2016 12:10:33 PM(UTC)
Whirlpool top load washer agitate but intermittent when spin (Washer Repair)
by phuong31 10/16/2015 7:56:27 AM(UTC)
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
Whirlpool Top load Washer clicks loudly in agitate mode and spin (Washer Repair)
by ggutshall87 10/14/2013 3:21:05 PM(UTC)
Whirlpool Top Load Washer (Washer Repair)
by stevesims 10/29/2012 10:06:36 AM(UTC)
whirlpool top load washer knocks during spin (Washer Repair)
by Jim O 9/24/2012 6:58:09 PM(UTC)
Whirlpool Top Load Washer no water (Washer Repair)
by al-lawn 7/27/2012 2:02:32 PM(UTC)
by tfontana43 6/18/2012 11:34:29 AM(UTC)
whirlpool top load washer won't spin. replaced coupler and clutch (Washer Repair)
by kodiakmook 1/22/2012 7:17:55 PM(UTC)
Whirlpool top load washer sqeal on spin UP (Washer Repair)
by squealer 6/25/2011 8:12:27 PM(UTC)
Whirlpool Top Load Washer not balanced (Washer Repair)
by Jerry Terkelson 3/25/2011 12:25:52 PM(UTC)
by JJM63 1/8/2011 12:56:39 PM(UTC)
