2 Pages<12
ma-henry
#11 Posted : Thursday, November 14, 2013 6:29:26 PM(UTC)
ma-henry
I replaced the large belt. I moved the pump all the way to the right and the trans would still not spin
Appliance Ninja
#12 Posted : Friday, November 15, 2013 8:05:50 AM(UTC)
Appliance Ninja
When the unit is supposed to be spinning, does the transmission turn easily by hand and will it come up to speed if you help it?
ma-henry
#13 Posted : Friday, November 15, 2013 8:34:40 AM(UTC)
ma-henry
It will start spinning when I help it. It seems like there is resistance when you hand spin it.
Appliance Ninja
#14 Posted : Friday, November 15, 2013 8:38:19 AM(UTC)
Appliance Ninja
I would replace the pump belt and see if it makes any difference since you have replaced the brake already. If the center stem kit was binding, it would not spin really much at all, even if once started by hand. The motor pulley may come into the equation, too, but I would start with replacing the pump belt. The belt set available below.
Whirlpool 12112425 Pump and Drive Belts - AppliancePartsPros.com
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
Maytag Washer Won't Spin (Washer Repair)
by DJames 9/6/2015 5:36:58 PM(UTC)
Maytag Washer won't spin. (Washer Repair)
by spectre_ 1/19/2015 5:24:12 PM(UTC)
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
by ProfKenn 11/21/2013 6:18:07 PM(UTC)
Maytag washer won't spin and there is a burning smell (Washer Repair)
by figureguy 4/6/2013 11:59:49 AM(UTC)
Maytag Washer won't spin sometimes! (Washer Repair)
by fixit4meNOW 3/21/2013 11:11:25 AM(UTC)
Maytag washer won't spin (Washer Repair)
by Hupper 10/10/2011 12:48:31 PM(UTC)
by treehugger 8/25/2011 12:44:37 PM(UTC)
by erichmann 4/11/2011 6:06:40 PM(UTC)
by randowhite 3/31/2011 11:45:17 AM(UTC)
Maytag Washer Won't Spin or Agitate (Washer Repair)
by scott805 11/16/2010 12:09:40 PM(UTC)
Maytag Washer won't spin (Washer Repair)
by starkdr1 2/27/2010 10:05:08 AM(UTC)
2 Pages<12
