Unit motor coupling keeps breaking; just replaced motor coupling 3 days ago
When you replace the coupling, are you pounding them on securely so the face of the motor and gearcase shaft are flush with the coupling insert?
Groups: Expert
Also check how basket stops after spin. If it stops hard, that can damage the coupler. In that case, the brakes need servicing. Also be sure to only purchase Whirlpool FSP couplers. Don't buy the cheap knockoffs, they are junk.
Eric
Originally Posted by: fairbank56  Also check how basket stops after spin. If it stops hard, that can damage the coupler. In that case, the brakes need servicing. Also be sure to only purchase Whirlpool FSP couplers. Don't buy the cheap knockoffs, they are junk.
Eric Thank you so much for your help Fairbank56 and Appliance Ninja.
