Awsome
#1 Posted : Thursday, November 14, 2013 7:54:34 AM(UTC)
Awsome
Unit motor coupling keeps breaking; just replaced motor coupling 3 days ago
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 8:00:28 AM(UTC)
Appliance Ninja
When you replace the coupling, are you pounding them on securely so the face of the motor and gearcase shaft are flush with the coupling insert?
fairbank56
#3 Posted : Thursday, November 14, 2013 12:01:02 PM(UTC)
fairbank56
Groups: Expert
Also check how basket stops after spin. If it stops hard, that can damage the coupler. In that case, the brakes need servicing. Also be sure to only purchase Whirlpool FSP couplers. Don't buy the cheap knockoffs, they are junk.
Eric
Awsome
#4 Posted : Thursday, November 14, 2013 2:45:08 PM(UTC)
Awsome
Eric
Thank you so much for your help Fairbank56 and Appliance Ninja.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
