greenfrog1967
#1 Posted : Wednesday, November 13, 2013 10:08:57 AM(UTC)
greenfrog1967
ok so my ice maker stopped making ice so I looked up u-tube videos and figured to start with the water valve. bought the part and replaced. didn't solve the prob. took off new part and put on old part. bought the ice maker and replaced it. I hear the water fill up but after 18 hours no ice. I rolled the refrigerator out and there is water on the ground. any ideas on what it might be... im thinking the line might be frozen and maybe I didn't secure the water connection on the valve? will the water spurt out of the line is frozen with a proper connection? Thanks in advance..
Mike
greenfrog1967
#2 Posted : Wednesday, November 13, 2013 10:14:22 AM(UTC)
greenfrog1967
Mike
oh and the brand is lg.. the drop down menu did not have that
Appliance Ninja
#3 Posted : Wednesday, November 13, 2013 10:17:54 AM(UTC)
Appliance Ninja
If you remove the line from the water valve that feeds the ice maker, can you blow through it, verifying the fill tube to the ice maker is clear?
greenfrog1967
#4 Posted : Wednesday, November 13, 2013 10:23:52 AM(UTC)
greenfrog1967
no I can not... it seems to be blocked
Appliance Ninja
#5 Posted : Wednesday, November 13, 2013 10:40:50 AM(UTC)
Appliance Ninja
That is likely your only problem, the water cannot get to the ice maker. Thaw the fill tube and you should be good to go!
greenfrog1967
#6 Posted : Wednesday, November 13, 2013 1:40:37 PM(UTC)
greenfrog1967
I now can blow threw the line but noticed the tube was loose on the compression fitting to the water line on the water valve. When I took it off originally I pulled real hard till it came off and im sure I messed it up so now I have ordered a new one.. I didn't realize you need to push down on the ring like thing to release it. your advice s greatly appreciated ninja, Thank you...
Appliance Ninja
#7 Posted : Wednesday, November 13, 2013 1:44:24 PM(UTC)
Appliance Ninja
Those fittings are called Guest fittings, named for their inventor, John Guest. The washer you push on releases the "teeth" that secure the hose into the valve when installed. Sorry I did not mention that. You should be good to go once you get that new valve, nice work!
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
