Washer *sometimes* leaks
If there was no water in the base of the machine, I doubt the main tub seal is at fault. It is more likely that the stand pipe that the machine drains into is backing up and leaking. You should be able to tell if that is the case by filling the tub up and then drain it and watch that pipe to see if it overflows. Let me know what you find. You may need to do a couple tub fill and drain cycles to get the drain line full enough to cause a back up, if it is indeed the case.
