My washer has suddenly stopped spinning during the wash cycle. It fills with water, then I hear nothing and it eventually drains. I thought at first it was maybe the load, so I emptied it and just tried doing another cycle...same thing happens. It completely fills and then eventually drains with nothing in it without spinning/agitating.
Before I call my home warranty and pay a repair guy I was wondering what are some easy things to check for this particular model?
Any and all help is truly appreciated!
~T
Groups: Expert
Take the front panel off by inserting putty knife into the front of the top groove in line with the lid opening on each end to release the clips while pulling on panel. Tilt out and lift from cabinet. Check circuit board on top of motor. Should be a flashing LED on the right side of the circuit board that will indicate error codes. What is the flash rate?
Eric
I'm at work now and won't be home until late tonight. I'll post it as soon as I can.
